leider wird nach einem Upgrade auf die neueste Version mein Liveconfig nicht mehr angezeigt.
Server wurde komplett neu gestartet.
liveconfig log zeigt folgende Einträge.
[2014/12/25 11:27:41.816000] [14852|14852] LiveConfig 1.8.0-3350 starting...
[2014/12/25 11:27:41.816963] [14852|14852] Database driver loaded: MySQL (5.5.36)
[2014/12/25 11:27:41.818578] [14852|14852] License is valid.
[2014/12/25 11:27:41.820593] [14856|14856] Client child started...
[2014/12/25 11:27:41.820693] [14855|14855] Server child started...
[2014/12/25 11:27:42.018018] [14856|14859] [LUA] Loading custom Lua settings from '/usr/lib/liveconfig/lua/custom.lua'
[2014/12/25 11:27:42.218556] [14856|14860] (last message repeated 2 times)
[2014/12/25 11:27:42.218556] [14856|14860] Process 14869 terminated with status 254
[2014/12/25 11:27:42.221492] [14856|14860] Can't run /usr/lib/liveconfig/lua/liveconfig.lua: /usr/lib/liveconfig/lua/web.lua:1208: attempt to perform arithmetic on a nil value
stack traceback:
/usr/lib/liveconfig/lua/web.lua:1208: in function 'addPHP'
/usr/lib/liveconfig/lua/custom.lua:1: in main chunk
[C]: in function 'dofile'
/usr/lib/liveconfig/lua/liveconfig.lua:414: in main chunk
[2014/12/25 11:27:42.222374] [14854|14854] Client child process 14856 terminated; return code: 77
[2014/12/25 11:27:42.222405] [14854|14854] Resource usage statistics:
[2014/12/25 11:27:42.222409] [14854|14854] Uptime: 1 sec.
[2014/12/25 11:27:42.222412] [14854|14854] User time: 0.0081
[2014/12/25 11:27:42.222415] [14854|14854] System time: 0.0026
[2014/12/25 11:27:42.222418] [14854|14854] Error while creating client child process - aborting...
[2014/12/25 11:27:42.310510] [14855|14855] Server child terminating... (shutdown=0, exitcode=0)
[2014/12/25 11:27:42.310561] [14855|14855] LiveConfig terminated.
[2014/12/25 11:27:42.312692] [14855|14855] Closing log file
[2014/12/25 11:27:42.313575] [14854|14854] Server child process 14855 terminated; return code: 0
[2014/12/25 11:27:42.313606] [14854|14854] Resource usage statistics:
[2014/12/25 11:27:42.313614] [14854|14854] Uptime: 1 sec.
[2014/12/25 11:27:42.313621] [14854|14854] User time: 0.0001
[2014/12/25 11:27:42.313628] [14854|14854] System time: 0.0001
[2014/12/25 11:27:42.313642] [14854|14854] LiveConfig terminated.
[2014/12/25 11:27:42.314227] [14854|14854] Closing log file
