My struggle with lcbackup.
  • My first experience with the Backup feature in LC3 is that of confusion as if it still were a Beta release. In fact I am still very reluctant to call a bug report or complaint because I am still unsure what is expected behavior. The only I do here is to transmit my confusion.
    I will first present what I did to get it somewhat working. I decided to keep it simple by choosing for tar with local storage. I hope lcbackup is prepared to run some pre/post scripts to (un)mount the destination folder after/before backup?
    My initial test setup:
    • Server A
      • Liveconfig host
      • 1st DNS
      • Client's HTTP
      • Client's Database
    • Server B
      • Mail
      • 2nd DNS
      • Company HTTP & Database, for Roundcube and other apps
    This tested okay so far using the following accounts outline:
    • Admin account
      • Account A (company use of server A)
        • main domain with some tool apps
      • Account B (company use of server B)
        • mail subdomain on server B with Roundcube
      • Customer My Company
        • Reseller account (to separate client accounts)
          • Client A (test account)
    My steps to configure Backup.
    • Activate Backup on all servers where it is needed.
      • LC menu: ☞ Servers ☞ localhost (Column ID) ☞ BACK-UP (Tab)
      • Click [ Add storage ]
        • Form data
          • Description: xxx backup
          • Type: tar
          • Directory: /var/backups/liveconfig
        • Click [ 🗸 Save ]
      • Check that Services ☞ lcbackup shows a circled check mark (service is running)
      • Which should be consistent with the result of the following command:
        • sudo systemctl status backup
      • Remedy when unloaded, inactive etc.
        sudo systemctl unmask lcbackup
        sudo systemctl enable lcbackup
        sudo systemctl start lcbackup
    Then I wanted to test primarily the function of manual backup as advertised in the UI. My main interest was to use this to migrate accounts from my old server. I activated this for the Client A test account which was a sub-account of the Company Reseller (see my test account outline):
    • Customers ☞ click company's row ☞ click button [ Log in as user Client A ]
      • Customers ☞ click client A row ☞ click ACCOUNTS (tab) ☞ click account summary
      • Click BACKUP (tab)
        • activate allow customer to trigger backup manually
        • set (for instance) keep up to 3 manual backups and minimum time to wait between two backups: 10 minutes.
        • Click button [ 🗸 Save ]
      • I clicked back to Client A's OVERVIEW tab and clicked button [ Log in as user 'Client A' ]
    I looked for the promised means to manually trigger a backup by client A but I did not find it anywhere. Since there is no documentation I keep doubting if this a bug or a configuration error. I first thought it might be an issue with reseller sub accounts, but the reseller has the same manual backup setting and after activating it and logging in as, I could not find any there either. What am I missing?
    Then I started playing around with Backup schedules. I made some test schedules and then:
    • I checked the backup location at /var/backup/liveconfig. There were (scheduled) backups as set up in menu BACKUP ☞ SCHEDULES
    • They apparently were only related to the accounts A and B I created as the admin for admin.
      • Their schedules are visible in their account setting, but I cannot change the retention. The Delete button is not an option here because it will delete the whole account.
      • When I compare that with the Reseller created under the company customer then I notice in the account setting that you can still edit the schedules there.
        • Is that because there were no backups yet?
        • Or is that because they can only set once?
      • Apparently the retention setting activates the schedule, but you cannot change the retention any more when there was a backup created.
        • I deleted all backups of account A and still the retention could not be ediited.
    • The location to restore I found in WEBSPACE ☞ BACKUP, with a page wide select select box to switch between the accounts. In both I could enter the restore page after clicking one of the retained backups in the list.
      • The Reseller had no WEBSPACE of its own, so there was no way to check its BACKUP tab there.
      • The Client A WEBSPACE ☞ BACKUP list was empty, as there was no way in their account setting to set the backup retention either.
    So far my superficial impressions. I wanted to translate this into German but then I found out that I then would loose all outlines. Sorry about that. Now I have to revert to writing my own scripts, because beside being unable to trigger manual backup, I don't see an option to upload backup files or even see that the functionality exists.
