web apps problem
  • Regards,
    I have a problem with installing web apps,
    installation works normally while the panel is set to work in English language,
    when I switch on Serbian language, installation abort at the third step,
    when i click on: finishes,
    installation broke at "downloading packet"
  • I can confirm this bug, I've just tested this with WordPress installation in serbian language.
    (FYI: there's a log in ~/logs/appinstall.log containing all relevant output when installing an application)
    It seems to be a bug "only" in the web installer scripts, so we'll fix this today (no need to update LiveConfig, just restart or wait up to 24 hours to get the updated installer scripts)
  • Ok,
    now it work, but
    does not work Joomla and Drupal in serbian language,
    and Drupal does not work in english too.
    logs for drupal:
    PHP Warning: copy(/var/cache/liveconfig/downloads/drupal-7.34.de.po): failed to open stream: No such file or directory in /var/cache/liveconfig/installer/wai-drupal-7.34-1.php on line 136
    for joomla:
    PHP Notice: Undefined index: sr in /var/cache/liveconfig/installer/wai-joomla-3.3.6-1.php on line 200
    PHP Warning: file_get_contents(/var/www/uputstva/apps/srpskajoomla/installation/configuration.php-dist): failed to open stream: No such file or directory in /var/cache/liveconfig/installer/wai-joomla-3.3.6-1.php on line 357
