ERROR -- aborting SQL: 'INSERT INTO BACKUPS
    nach dem aktuellen Update habe ich folgenden Fehler bezüglich der Backup Routine:
    [2022/06/23 04:00:49.102165] [1700099|1700099] ERROR: Releasing db connection, but still have open statements
    [2022/06/23 04:00:49.102194] [1700099|1700099] aborting SQL: 'INSERT INTO BACKUPS ( B_CONTRACTID, B_CREATED, B_USERID, B_PLANID, B_NOTIFY, B_NOTIFYADDR) VALUES ( ?, ?, ?, ?, ?, ?)'
    [2022/06/23 04:00:49.102302] [1700099|1700099] aborting SQL: 'SELECT DISTINCT HC_ID, HC_NAME, HC_PLANID, BP_ID, BP_WEBSPACE, BP_MAILSPACE, BP_DATABASES, HPB_KEEP, HCB_KEEP, DB_CONTRACTID FROM BACKUPTIMES LEFT JOIN BACKUPPLANS ON ( BT_PLANID = BP_ID ) LEFT JOIN HOSTINGCONTRACTSBACKUP ON ( BP_ID = HCB_BACKUPPLANID ) LEF>
    [2022/06/23 04:00:49.102394] [1700099|1700099] internal cron: database connection failed: mysql_stmt_execute: (1452) Cannot add or update a child row: a foreign key constraint fails (`LIVECONFIG`.`BACKUPS`, CONSTRAINT `BACKUPS_ibfk_2` FOREIGN KEY (`B_USERID`) REFERENCES `USERS` (`U_ID`) ON DELETE SET NULL)
