Hallo miteinander,
vielleicht hat jemand einen Tipp für mich, der E-Mail Empfang und Versand mit Liveconfig klappt einfach nicht richtig.
openSUSE-123-64-minimal:~ # postconf -n
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
append_dot_mydomain = no
biff = no
broken_sasl_auth_clients = yes
command_directory = /usr/sbin
config_directory = /etc/postfix
daemon_directory = /usr/lib/postfix
data_directory = /var/lib/postfix
dovecot_destination_recipient_limit = 1
inet_interfaces = all
mail_owner = postfix
mailbox_size_limit = 0
message_size_limit = 26214400
mydestination = localhost.localdomain, localhost, $myhostname
myhostname = openSUSE-123-64-minimal
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
queue_directory = /var/spool/postfix
readme_directory = no
recipient_delimiter = +
relayhost =
setgid_group = maildrop
show_user_unknown_table_name = no
smtp_tls_CAfile = /etc/ssl/ca-bundle.pem
smtp_tls_security_level = may
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_banner = $myhostname ESMTP $mail_name
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_invalid_hostname, reject_unknown_reverse_client_hostname, reject_rbl_client ix.dnsbl.manitu.net, reject_rbl_client sbl-xbl.spamhaus.org
smtpd_discard_ehlo_keywords = silent-discard, dsn
smtpd_helo_required = yes
smtpd_helo_restrictions = reject_invalid_helo_hostname
smtpd_recipient_limit = 250
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, reject_unknown_recipient_domain, check_recipient_access hash:/etc/postfix/recipient_access
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $mydomain
smtpd_sasl_path = private/auth
smtpd_sasl_security_options = noanonymous
smtpd_sasl_type = dovecot
smtpd_sender_restrictions = permit_mynetworks, reject_unknown_address, reject_unknown_sender_domain, reject_non_fqdn_sender, check_sender_access hash:/etc/postfix/sender_access
virtual_alias_maps = hash:/etc/postfix/virtual_alias
virtual_gid_maps = static:12
virtual_mailbox_base = /var/mail
virtual_mailbox_domains = hash:/etc/postfix/virtual_domains
virtual_mailbox_maps = hash:/etc/postfix/virtual_alias
virtual_minimum_uid = 8
virtual_transport = dovecot
virtual_uid_maps = static:8
Alles anzeigen
und
ZitatAlles anzeigenopenSUSE-123-64-minimal:~ # /etc/init.d/postfix status
Checking for service Postfix: running
postfix.service - Postfix Mail Transport Agent
Loaded: loaded (/usr/lib/systemd/system/postfix.service; enabled)
Active: active (running) since Thu, 2014-03-13 13:22:20 CET; 9min ago
Process: 2181 ExecStartPost=/etc/postfix/system/cond_slp register (code=exited, status=0/SUCCESS)
Process: 2173 ExecStartPost=/etc/postfix/system/wait_qmgr 60 (code=exited, status=0/SUCCESS)
Process: 2084 ExecStart=/usr/sbin/postfix start (code=exited, status=0/SUCCESS)
Process: 2081 ExecStartPre=/etc/postfix/system/update_postmaps (code=exited, status=0/SUCCESS)
Process: 2078 ExecStartPre=/etc/postfix/system/update_chroot (code=exited, status=0/SUCCESS)
Process: 2075 ExecStartPre=/etc/postfix/system/config_postfix (code=exited, status=0/SUCCESS)
Process: 2066 ExecStartPre=/bin/echo Starting mail service (Postfix) (code=exited, status=0/SUCCESS)
Main PID: 2172 (master)
CGroup: name=systemd:/system/postfix.service
â 2172 /usr/lib/postfix/master
â 2179 pickup -l -t fifo -u -c
â 2180 qmgr -l -t fifo -u
â 2448 proxymap -t unix -u
â 2504 anvil -l -t unix -u -c
Mar 13 13:31:52 openSUSE-123-64-minimal postfix/smtpd[2538]: connect from grafitec.ro[89.122.218.16]
Mar 13 13:31:52 openSUSE-123-64-minimal postfix/smtpd[2538]: warning: SASL: Connect to private/auth failed: Connection refused
Mar 13 13:31:52 openSUSE-123-64-minimal postfix/smtpd[2538]: fatal: no SASL authentication mechanisms
Mar 13 13:31:52 openSUSE-123-64-minimal postfix/smtpd[2539]: connect from localhost[127.0.0.1]
Mar 13 13:31:52 openSUSE-123-64-minimal postfix/smtpd[2539]: warning: SASL: Connect to private/auth failed: Connection refused
Mar 13 13:31:52 openSUSE-123-64-minimal postfix/smtpd[2539]: fatal: no SASL authentication mechanisms
Mar 13 13:31:53 openSUSE-123-64-minimal postfix/master[2172]: warning: process /usr/lib/postfix/smtpd pid 2537 exit status 1
Mar 13 13:31:53 openSUSE-123-64-minimal postfix/master[2172]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Mar 13 13:31:53 openSUSE-123-64-minimal postfix/master[2172]: warning: process /usr/lib/postfix/smtpd pid 2538 exit status 1
Mar 13 13:31:53 openSUSE-123-64-minimal postfix/master[2172]: warning: process /usr/lib/postfix/smtpd pid 2539 exit status 1
Mir sticht besonders diese Meldung in's Auge:
ZitatMar 13 13:30:51 openSUSE-123-64-minimal postfix/smtpd[2502]: connect from mail-yh0-f45.google.com[209.85.213.45]
Mar 13 13:30:51 openSUSE-123-64-minimal postfix/smtpd[2502]: warning: SASL: Connect to private/auth failed: Connection refused
Mar 13 13:30:51 openSUSE-123-64-minimal postfix/smtpd[2502]: fatal: no SASL authentication mechanisms
